ERROR
Wenn in ArcGIS for Power BI versucht wird, eine Tabelle mit Längen- und Breitengraden zu laden, wird der folgende Fehler zurückgegeben:
Error: Can't display this visual. The Latitude bucket doesn't support measures or aggregated numbers.
Erstellen Sie Ausnahmen in Portal for ArcGIS und ArcGIS Server. Genauere Anweisungen hierzu finden Sie unter ArcGIS for Microsoft 365: Konfigurieren von Cross-Origin Resource Sharing (CORS) in ArcGIS Enterprise.
Wenden Sie sich an die IT-Abteilung, um URL-Ausnahmen in der Organisation zu erstellen. Informationen zu URL-Ausnahmen finden Sie unter ArcGIS for Microsoft 365: ArcGIS for Power BI Secure Networks.
Note: ArcGIS Online has certain domain requirements that must also be met. Suppose an organization decides to leverage its enterprise deployments with features like geocoding, ArcGIS Living Atlas, basemaps, imagery, demographics, infrastructure, and environmental data. In that case, ensure the network can access these additional domains.
If an organization's security policy disallows wildcards, refer to PDF: Domain Requirements for ArcGIS Online. Note that users must be signed in with an organizational account to view either of these documents, as they are located in the secure document section of the ArcGIS Trust Center https://trust.arcgis.com/.
Artikel-ID: 000032440
