BUG
Datenbankverbindungen zu SQL Server schlagen fehl, wenn Microsoft ODBC Driver 18 installiert ist
Last Published: July 28, 2025
Beschreibung
When the Microsoft ODBC driver 18 has been installed on a client machine, the following connection errors is encountered when connecting to a SQL Server database from an ArcGIS client.
Connection error
Failed to connect to the specified DBMS instance.
A database connection exception has occurred.
Failure to access the DBMS server[].
Or,
Connection error
Unable to get database list.
A database connection exception has occurred. Unable to connect to database server to retrieve database list; please verify your server name, user name, and password info and try again.
example connection error
Ursache
Microsoft ODBC Driver 18 for SQL Server includes changes related to encrypted connections that can affect Database Connection behavior in ArcGIS.
These changes include:
  • A change to the default value of the `Encrypt` connection option from ’No’ to ‘Yes’.
  • The TrustServerCertificate is not tied to the client-side Encrypt setting.
Problemumgehung
This bug has been addressed in the following patches and releases:
  • ArcGIS Pro 2.6.10
  • ArcGIS Pro 2.7.7
  • ArcGIS Pro 2.8.7
  • ArcGIS Pro 2.9.4
  • ArcGIS Pro 3.0
  • ArcGIS Server 10.8.1 Utility Network Patch 7
  • ArcGIS Server 10.9.1 Utility Network and Data Management Patch 2
Artikel-ID: 000027508
Zugehörige Informationen
Zu Download-Optionen wechseln
