HOW TO
Instructions provided describe how to create contours from XY data using 3D Analyst.
This tool is documented in ArcGIS Desktop Help > Contents > ArcCatalog > Exploring the values in a table > Creating new data sources from the values in a table.
These interpolators are described in detail in:
ArcGIS Desktop Help > Contents > Extensions > 3D Analyst > Creating Surface models
See the ArcGIS Desktop Help > Contents > Extensions > 3D Analyst > Creating Surface models.
For information can be found in the ArcGIS Desktop Help > Contents > Extensions > 3D Analyst > Analyzing surfaces > Deriving contour lines from a surface.
Artikel-ID: 000006571
