HOW TO
The direction of multiple line features can be calculated from their start and end point coordinates by using the Field Calculator.
The instructions provided describe how to calculate the line direction of multiple features using a batch process.
90-math.degrees(math.atan2(( !END_Y! - !START_Y! ),( !END_X! - !START_X! )))
def quadrant(NorthAzimuth): if ((NorthAzimuth>=0) & (NorthAzimuth<90)): quad = "N "+str(NorthAzimuth)+" E" elif ((NorthAzimuth>=90) & (NorthAzimuth<180)): quad = "S "+str(180-NorthAzimuth)+" E" elif ((NorthAzimuth>=180) & (NorthAzimuth<270)): quad = "S "+str(NorthAzimuth-180)+" W" else: quad = "N "+str(360-NorthAzimuth)+" W" return quad
Artikel-ID: 000015375
