PROBLEM
Ein Punktszenen-Layer, der in ArcGIS Pro 1.4 erstellt wurde, wird in einer vorherigen Version von ArcGIS Pro nicht gezeichnet
Last Published: April 24, 2024
Beschreibung
When adding point scene layers created in ArcGIS Pro 1.4 to a scene in ArcGIS Pro 1.3.1 or earlier, the layer does not draw.
Ursache
At ArcGIS Pro 1.4, the scene layer specification was updated to version 1.6, which contains breaking changes for the client application. So when a scene layer is saved using ArcGIS Pro 1.4, the client application of the scene layer specification, previous versions of ArcGIS Pro cannot draw the layer.
Lösung oder Problemumgehung
Upgrade ArcGIS Pro to 1.4 to consume point scene layers created with ArcGIS Pro 1.4.
Artikel-ID: 000015263
Zu Download-Optionen wechseln
