CÓMO
When using the Select by Attributes tool, query operators such as IN, LIKE, OR, and NOT can be used to determine the type of selection for multiple values. Refer to ArcMap: SQL reference for query expressions used in ArcGIS for more information on the query operators types.
The following workflow uses the IN query operator to select multiple values. This workflow is also applicable to the other query operators, LIKE, OR, and NOT.
Note: If it is a text field, apply single quotes around each value.
The following is an example of the query:
<field name> IN (<field value>, <field value>)
Note: This method can also be used to select numeric and string values.
Descargar la aplicación de soporte de Esri
