CÓMO
seleccionar la transformación geográfica (datum) correcta al proyectar entre datums
Last Published: January 4, 2024
Resumen
It is necessary to specify a geographic (datum) transformation when using the ArcToolbox Project Wizard (ArcGIS version 8.x) or Project tool (ArcGIS versions 9.x, 10.x) to project shapefiles or geodatabase feature classes between different geographic coordinate systems (datums).
The user must also select an appropriate Geographic (datum) transformation in ArcMap when displaying data that are projected on different datums. For more information on selecting an appropriate Geographic transformation, refer to ArcGIS Help: Choosing an appropriate transformation.
Procedimiento
Click a link in the Related Information section to access a list of the geographic (datum) transformation methods available in ArcGIS, and the geographic areas for which these transformations are appropriate for the version of ArcGIS Desktop used.
Datum transformations work in either direction. For example, the transformation listed as NAD_1927_to_NAD_1983_NADCON transforms from NAD 1983 to NAD 1927, as well as from NAD 1927 to NAD 1983.
Id. de artículo:000004829
Contactar con soporte técnico
Descargar la aplicación de soporte de Esri
Ir a las opciones de descarga
