English
Error: Attempt to configure data store failed. Extended error message: Failed to configure tile cache data store
Error Message
The default installation location for ArcGIS Data Store on Windows is C:\Program files\arcgis\datastore. If ArcGIS Data Store is installed on a non-default drive on Windows computers, the configuration of the tile cache data store may fail with the following error:
Error:
Attempt to configure data store failed.. Extended error message: Failed to configure tile cache data store. Extended error message: Internal Server Error.
Cause
When installing ArcGIS Data Store to a non-default drive, the folder's name cannot contain spaces.
Solution or Workaround
Use one of the following workarounds to resolve this issue.
  1. Install ArcGIS Data Store to the default C:\ drive. For example, install to: C:\Program Files\arcgis\datastore
  2. Install ArcGIS Data Store to a non-default drive, making sure the folder’s name does not contain spaces. For example, install to: D:\arcgis_datastore_install_dir
