PROBLEM
A point scene layer created in ArcGIS Pro 1.4 does not draw in a previous version of ArcGIS Pro
When adding point scene layers created in ArcGIS Pro 1.4 to a scene in ArcGIS Pro 1.3.1 or earlier, the layer does not draw.
Cause
At ArcGIS Pro 1.4, the scene layer specification was updated to version 1.6, which contains breaking changes for the client application. So when a scene layer is saved using ArcGIS Pro 1.4, the client application of the scene layer specification, previous versions of ArcGIS Pro cannot draw the layer.
Solution or Workaround
Upgrade ArcGIS Pro to 1.4 to consume point scene layers created with ArcGIS Pro 1.4.
Article ID:000015263
Software:
  • ArcGIS Pro
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
