English
How To: Check the status of a Compress operation
Summary
Running a Compress on a regular basis is a necessary operation for managing and maintaining a healthy versioned geodatabase. This operation removes states that are no longer referenced by a version, and also moves records from the delta tables over to their corresponding business tables. How often the data is being edited impacts the duration for the Compress operation to complete. At 10.3 and 10.2.1 Utility and Telco Patch 1, some additional Compress logging was introduced to explain what is happening during this entire process.
Procedure
To obtain this additional Compress logging information, do the following:
  1. Create the COMPRESS_LOG table, if it does not already exist. This table is automatically created when the first Compress operation is executed.
  2. Create a compress audit table for inserting records into when the COMPRESS_STATUS column in the COMPRESS_LOG table changes.
  3. Create a trigger on the COMPRESS_LOG table to capture the changes to the COMPRESS_STATUS columns, and write them into the compress audit table.
    • For an Oracle geodatabase:
      CREATE TABLE SDE.COMPRESS_LOG
         (    "SDE_ID" NUMBER(*,0) NOT NULL ENABLE,
              "SERVER_ID" NUMBER(*,0) NOT NULL ENABLE,
              "DIRECT_CONNECT" VARCHAR2(1) NOT NULL ENABLE,
              "COMPRESS_START" DATE NOT NULL ENABLE,
              "START_STATE_COUNT" NUMBER(*,0) NOT NULL ENABLE,
              "COMPRESS_END" DATE,
              "END_STATE_COUNT" NUMBER(*,0),
              "COMPRESS_STATUS" VARCHAR2(20)
        PCTFREE 10 PCTUSED 40 INITRANS 1 MAXTRANS 255 NOCOMPRESS LOGGING
        STORAGE(INITIAL 131072 NEXT 131072 MINEXTENTS 1 MAXEXTENTS 2147483645
        PCTINCREASE 0 FREELISTS 1 FREELIST GROUPS 1 BUFFER_POOL DEFAULT FLASH_CACHE
        DEFAULT CELL_FLASH_CACHE DEFAULT)
        TABLESPACE SDE;
      CREATE TABLE SDE.COMPRESS_LOG_TRACKER_TAB
      (SDE_ID NUMBER(*,0),
       SERVER_ID NUMBER(*,0),
       LOG_DATE DATE,
       COMPRESS_END DATE,
       COMPRESS_STATUS VARCHAR2(20),
       START_STATE_COUNT NUMBER(*,0),
       END_STATE_COUNT NUMBER(*,0))
        TABLESPACE SDE;
      CREATE OR REPLACE TRIGGER SDE.COMPRESS_LOG_TRACKER_TRIG
      AFTER INSERT OR UPDATE
         OF COMPRESS_STATUS
         ON SDE.COMPRESS_LOG
         REFERENCING NEW AS new
         FOR EACH ROW
      DECLARE
        BEGIN
         INSERT INTO SDE.COMPRESS_LOG_TRACKER_TAB (SDE_ID, SERVER_ID, LOG_DATE, COMPRESS_END, COMPRESS_STATUS, START_STATE_COUNT, END_STATE_COUNT)
         VALUES (:new.SDE_ID, :new.SERVER_ID, sysdate, :new.COMPRESS_END, :new.COMPRESS_STATUS, :new.START_STATE_COUNT, :new.END_STATE_COUNT);
        EXCEPTION
          WHEN OTHERS THEN
              RAISE;
      END;
       Query the Compress Tracker Table :
      SQL> select * from sde.compress_log_tracker_tab;
          SDE_ID  SERVER_ID LOG_DATE                 COMPRESS_END             COMPRESS_STATUS      START_STATE_COUNT END_STATE_COUNT
              51       5896 Tue 07-Jul-2015 10:55:16                          IN PROGRESS                         15
              51       5896 Tue 07-Jul-2015 10:55:16                          DELETE LEAF STATES                  15              15
              51       5896 Tue 07-Jul-2015 10:55:17                          TRIMMING                            15              13
              51       5896 Tue 07-Jul-2015 10:55:17                          MOVE TO BASE                        15              13
              51       5896 Tue 07-Jul-2015 10:55:17 Tue 07-Jul-2015 10:55:17 SUCCESS                             15               1
      5 rows selected.
    • For a SQL Server geodatabase:
      CREATE TABLE [sde].[SDE_compress_log](
      	[compress_id] [int] IDENTITY(1,1) NOT NULL,
      	[sde_id] [int] NOT NULL,
      	[server_id] [int] NOT NULL,
      	[direct_connect] [varchar](1) NOT NULL,
      	[compress_start] [datetime] NOT NULL,
      	[start_state_count] [int] NOT NULL,
      	[compress_end] [datetime] NULL,
      	[end_state_count] [int] NULL,
      	[compress_status] [varchar](20) NULL,
       CONSTRAINT [compress_log_pk] PRIMARY KEY CLUSTERED
      	[compress_id] ASC
      )WITH (PAD_INDEX  = OFF, STATISTICS_NORECOMPUTE  = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS  = ON, ALLOW_PAGE_LOCKS  = ON) ON [PRIMARY]
      ) ON [PRIMARY]
      GO
      CREATE TABLE [sde].[SDE_COMPRESS_LOG_TRACKER_TAB]
         [SDE_ID] int  NULL,
         [SERVER_ID] int  NULL,
         [LOG_DATE] datetime  NULL,
         [COMPRESS_END] [datetime],
         [COMPRESS_STATUS] varchar(20),
         [START_STATE_COUNT] [int],
         [END_STATE_COUNT] [int]
      GO
      CREATE TRIGGER sde.SDE_COMPRESS_LOG_TRACKER_TRIG
         ON sde.SDE_COMPRESS_LOG
          AFTER INSERT, UPDATE
            AS
               BEGIN
                  SET  NOCOUNT  ON
                  /* column variables declaration*/
                  DECLARE
                     @new$SDE_ID int,
                     @new$SERVER_ID int,
                     @new$LOG_DATE datetime,
                     @new$COMPRESS_END datetime,
                     @new$COMPRESS_STATUS varchar(20),
                     @new$START_STATE_COUNT int,
                     @new$END_STATE_COUNT int
                  DECLARE
                      ForEachInsertedRowTriggerCursor CURSOR LOCAL FORWARD_ONLY READ_ONLY FOR
                        SELECT SDE_ID, SERVER_ID, sysdatetime(), COMPRESS_END, COMPRESS_STATUS, START_STATE_COUNT, END_STATE_COUNT
                        FROM inserted
                  OPEN ForEachInsertedRowTriggerCursor
                  FETCH ForEachInsertedRowTriggerCursor
                      INTO @new$SDE_ID, @new$SERVER_ID, @new$LOG_DATE, @new$COMPRESS_END, @new$COMPRESS_STATUS, @new$START_STATE_COUNT, @new$END_STATE_COUNT
                  WHILE @@fetch_status = 0
                     BEGIN
                        /* trigger implementation: begin*/
                        BEGIN
                           IF (UPDATE(COMPRESS_STATUS))
                              BEGIN
                                  INSERT sde.SDE_COMPRESS_LOG_TRACKER_TAB(SDE_ID, SERVER_ID, LOG_DATE, COMPRESS_END, COMPRESS_STATUS, START_STATE_COUNT, END_STATE_COUNT)
                                  VALUES (@new$SDE_ID, @new$SERVER_ID, sysdatetime(), @new$COMPRESS_END, @new$COMPRESS_STATUS, @new$START_STATE_COUNT, @new$END_STATE_COUNT)
                              END
                        END
                        /* trigger implementation: end*/
                     END
                  CLOSE ForEachInsertedRowTriggerCursor
                  DEALLOCATE ForEachInsertedRowTriggerCursor
               END
      GO
      select * from sde.SDE_COMPRESS_LOG_TRACKER_TAB
      go
             3035        9016 2015-07-02 12:36:07.690                    NULL IN PROGRESS                       8154            NULL
             3035        9016 2015-07-02 12:36:07.720                    NULL DELETE LEAF STATES                8154            8154
             3035        9016 2015-07-02 12:52:03.113                    NULL TRIMMING                          8154            6308
             3035        9016 2015-07-02 12:53:44.770                   NULL MOVE TO BASE                      8154            6306
             3035        9016 2015-07-02 12:56:12.637 2015-07-02 12:56:12.623 SUCCESS                           8154            6094
      (5 rows affected)
      If the SQL Server Enterprise Geodatabase is maintained by a DBO user (and not SDE), change the owner of the tables and trigger from SDE to DBO.
    • Description of each of the COMPRESS_STATUS operations:
      • IN PROGRESS - the compress operation has begun
      • DELETE LEAF STATESĀ - deletes all states that do not participate within a version's lineage
      • TRIMMING - collapses any candidate lineage of states into one state
      • MOVE TO BASE - moves rows from the Delta tables into the Base (business) table - if not blocked by another version
      • SUCCESS - the compress operation has completed successfully
Related Information
