English
Bug: After upgrading, some data stores fail to register with the error "PARENT_NOT_REGISTERED" in ArcGIS Server Manager 10.5
After upgrading from an older version of ArcGIS Server to ArcGIS Server 10.5, the ArcGIS Server Manager is unable to register the Big Data File Share, Raster store, or Cloud store as data stores, and the following error message is returned.
Error:
Cause
After upgrading from an older version of ArcGIS Server to 10.5, the new data items supported at ArcGIS Enterprise 10.5 (such as the big data file share, raster store, or cloud store) are not registered to ArcGIS Server. Therefore, users are unable to register a big data file share to be used by the GeoAnalytics Server, or a raster store to be used by the Raster Analysis server. Users also cannot register a cloud store if GIS resources and data are stored in Amazon Web Services or Microsoft Azure.
Workaround
Register the big data file share, raster store, and cloud store as data items in the ArcGIS Server Administrator Directory.
  1. Login to the ArcGIS Server Administrator Directory using the administrator account.
  2. Navigate to and select data registerItem.
  3. In the box next to Item, copy and place the following to add the cloud store data item:
"path": "/cloudStores",
"type": "datadir"
  1. Click Register Item to register the item to ArcGIS Server.
  2. Repeat steps 3 and 4 for the raster store and big data file share:
"path": "/rasterStores",
"type": "datadir"
"path": "/bigDataFileShares",
"type": "datadir"
  1. Register the big data file share, raster store, or cloud store as data stores in ArcGIS Server Manager.
