HOW TO
Find out what polygons are adjacent to other polygons or create an adjacency matrix
Summary
A matrix is a table that provides values for all row/column combinations. An adjacency matrix is a matrix that indicates whether features are or are not adjacent, or sharing edges.
Procedure
While Esri does not have a tool that directly creates adjacency matrices, there is a tool called Polygon Neighbors. This tool creates a table with a row for every shared edge in a dataset. The tool can also output values such as the total length of the shared edge and the number of vertices shared. This helps a user understand if adjacent polygons are sharing just an edge, or just vertices (for example, a corner to a corner). The user can then use this output and create custom Python code to create an adjacency matrix as needed.
Article ID:000014890
Software:
  • ArcGIS Desktop 1
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
