HOW TO
As of July 2016, all users with an Esri-enabled ArcGIS Online organizational account have access to self-paced e-learning classes. To allow members to access these courses, organizational administrators may be interested in enabling Esri access for all users.
#import system modules import urllib import urllib2 import json from pprint import pprint #Define functions def get_total_users(token, url_Key): """ Returns the total number of user's in an organization. """ max_Url = 'http://{0}.maps.arcgis.com/sharing/rest/portals/self/users?f=json&token={1}'.format( url_Key, token ) response = make_request(max_Url) return response['total'] def get_token(user, pw): """ Returns a token used to make user-specific requests. """ params = { 'f': 'json', 'password': pw, 'referer' : 'https://www.arcgis.com', 'username': user, } url = 'https://arcgis.com/sharing/rest/generateToken' json_Response = make_request(url, params) return json_Response['token'] def get_url_key(token): """ Returns the Url Key used """ URL= 'http://www.arcgis.com/sharing/rest/portals/self?f=json&token=' + token response = make_request(URL) url_Key = response['urlKey'] return url_Key def get_user_list(token, url_Key, total_Users): """ Returns a list of all users in an organization. """ start = 1 number = 100 user_List = list() while start-1 < total_Users: list_URL ='http://{0}.maps.arcgis.com/sharing/rest/portals/self/users?start={1}&num={2}&f=json&token={3}'.format( url_Key, str(start), str(number), token ) response = make_request(list_URL) for item in response['users']: user_List.append(item['username']) start += number return user_List def make_request(url, params=None): """ Handles all requests made via the REST API. """ if params: response = urllib2.urlopen(url, urllib.urlencode(params)).read() else: response = urllib2.urlopen(url).read() return json.loads(response) def update_myesri_access(user, url_Key, token): """ Updates MyEsri access for a single user. """ userURL ='https://{0}.maps.arcgis.com/sharing/rest/community/users/{1}/update'.format( url_Key, user ) params = { 'f':'json', 'token':token, 'usertype':'both' } response = make_request(userURL, params) #Main function if __name__ == "__main__": """ Prompts user for a username and password, generates a list of all users in an organization, then enables MyEsri access for all users. """ user = raw_input("Admin username: ") password = raw_input("Password: ") token = get_token(user, password) url_Key = get_url_key(token) total_Users = get_total_users(token, url_Key) all_Users = get_user_list(token, url_Key, total_Users) print("User List:") pprint(sorted(all_Users)) print("Enabling Esri Access") for user in all_Users: update_myesri_access(user, url_Key, token) print("Esri Access enabled")
Note: As these are script samples, Esri Support does not debug specific scenarios of the script failing or assist in customizing it further.
Get help from ArcGIS experts
Download the Esri Support App
