HOW TO
Use the Metadata Importer to import Metadata within an XML file into a Shapefile
Last Published: September 11, 2023
Summary
Upon downloading shapefiles from an ArcGIS Open Data site, the metadata is downloaded as a separate XML file.
      User-added image
      User-added image
Procedure
To include the metadata within the shapefile instead of in a separate XML file, the Metadata Importer can be used to import the XML file into the shapefile.
  1. Open ArcCatalog.
  2. Select the XML file to view the metadata within the description tab.
  3. To view the metadata in different styles navigate to Customize > ArcCatalog Options. On the Metadata tab, use the drop-down to select the desired style.
User-added image
  1. To copy metadata from the XML to the shapefile, open the Metadata Importer: from ArcToolbox > Conversion Tools > Metadata
     User-added image
  1. Input the XML file as the Source Metadata and the shapefile as the Target Metadata, and run the tool. The metadata from the XML file is then transferred to the metadata of the shapefile.
     User-added image
Article ID:000014647
Software:
  • ArcGIS Desktop 1
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
