English
Problem: SearchCursor returns no results after Select By Location is run
If a search cursor is run on a feature class, it returns all features. However, if a selection tool (such as Select By Location) is run prior to the search cursor, and nothing is selected, the search cursor returns no results.
Cause
This is expected behavior. ArcMap recognizes if a selection has been run on a feature class and only returns selected features. If no features were selected, no features are returned after the search has been run.
Solution or Workaround
To workaround this issue, use a Python script and add an if statement that clears any selections.
if count == 0:
  arcpy.SelectLayerByAttribute_management("Box","CLEAR_SELECTION")
