English
Problem: Labels for rasters with stretched symbology do not appear as expected when advanced labeling with more than two intervals is applied
When rendering a raster using the Minimum-Maximum stretch type, and the Edit High/Low Values option is selected, the stretch values along the color ramp display only the highest and lowest values, even when more than two intervals are applied. The labels for interval values between the lowest and highest values for the raster do not appear.
Label interval values between the lowest and highest values do not appear
Cause
This is a known limit. By default, the Edit High/Low Values option supports two labels (highest and lowest) when rendering a raster using the Minimum-Maximum stretch type.
When using the Minimum-Maximum stretch type, this issue also occurs if the raster display statistics is set to From Current Display Extent in the Statistics drop-down list, even if the Edit High/Low Values option is not selected.
Solution or Workaround
Follow the steps provided below as a workaround when using more than two intervals.
  1. Add the raster layer to the Table Of Contents
  2. In the Symbology tab of the raster layer properties, select a color ramp for the stretched symbology, and set the stretch type to Minimum-Maximum.
  3. Scroll down to the Statistics drop-down list, and select From Custom Settings (below)
  4. Insert the desired minimum and maximum values in the Min and Max fields respectively.
Screen shot of Steps 2, 3, and 4 for raster symbology settings
  1. Scroll back up, and change the label values according to the minimum and maximum values set in Step 3.
  2. Click Apply > OK to apply the changes and close the Layer Properties window.
Steps 5 and 6 - adjusting the label values
  1. Right-click the layer in the Table Of Contents, and click Save As Layer File. Name the layer, and click Save to save the layer.
  2. In the Symbology tab of the original raster layer, click the Import icon The Import icon to import the saved raster layer's symbology settings to the original raster layer.
  3. Browse to the saved raster layer name, and click Add > OK.
  4. Click the Labeling button to set the interval size and label names, and click OK.
Setting the interval size and label name in the Advanced Labeling window
  1. Click Apply > OK, and the raster labels appear as expected.
The expected outcome after performing the workaround
This issue does not occur in ArcGIS Desktop 10.5.
Related Information
