PROBLEM
Unable to select a layer in the Search Settings section of the District Lookup widget
When configuring the District Lookup widget in Web AppBuilder for ArcGIS, selecting a layer in the Search Settings section returns the following warning message:
Please select a polygon layer which has a related point layer.
Cause
The following are three possible reasons for this issue:
  • The data have a one-to-many (1:M) relationship. However, the layer in the District Lookup widget only requires a one-to-one (1:1) cardinality in the relationship class. For more information, refer to the following link: District Lookup widget
  • There is no relationship class associated with the data layer.
  • The data consist of on-the-fly relates, which are not maintained once the layer is published as a feature service.
Solution or Workaround
To resolve this issue, follow the steps below.
  1. In ArcMap, create a new 1:1 relationship class. For more information, refer to the following link: Creating a simple relationship class
  2. Publish the layer as a feature service before using the District Lookup widget in Web AppBuilder for ArcGIS. For more information, refer to the following link: Publishing a map service
Article ID:000014347
Software:
  • ArcGIS Web AppBuilder
  • ArcMap
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
