English
Error: Failed to connect to database. The geodatabase is not accepting connections. Please contact your geodatabase administrator
Error Message
In ArcGIS for Desktop, in some instances when attempting to establish a connection to a geodatabase the following error is returned.
Error:
Failed to connect to database. The geodatabase is not accepting connections. Please contact your geodatabase administrator.
image of error message
Cause
This issue occurs if the Geodatabase is accepting connections check box is unchecked in the database properties, which prevents new connections to be made to the geodatabase.
Solution or Workaround
Enable the Geodatabase is accepting connections option.
  1. In ArcMap, navigate to the Catalog pane.
  2. Right-click the target database > PropertiesConnections tab.
  3. Check the Geodatabase is accepting connections check box.
  4. Click Apply to confirm the new database connection settings.
Related Information
