ERROR
Layer is not in the webmap:<layername>
Error Message
When attempting to view the Information Lookup web application, the following error message is returned:
Error:
Layer is not in the webmap:[layername]
User-added image
Cause
The error occurs because the Lookup Layer setting is not properly configured for the query operation in the Information Lookup application. For the Information Lookup application to work, at least one layer must be selected in the Lookup Layers parameter for the query operation.
Solution or Workaround
The instructions provided describe how to select layer(s) to query in the Information Lookup application.
  1. In the item details page of the Information Lookup application, click Configure App to open the configuration panel for the application.
  2. Click the Lookup Layer tab.
  3. Scroll down to the Lookup Layers parameter, and check the check box for the layer(s) to be queried. Select at least one layer.
Select a layer.
  1. Click Save.
Article ID:000013854
Software:
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
