PROBLEM
Adding or deleting rasters in the mosaic dataset does not reflect in the published image service
Last Published: April 23, 2024
Adding or deleting rasters in the mosaic dataset is not reflected in the published image service.
Cause
After updating a GIS resource for a service, such as an MXD (map document) or raster dataset, the changes are not reflected in the service. Almost all types of ArcGIS Server web services reference a GIS resource. For example, map services reference an MXD, and an image service references a mosaic dataset. Adding or deleting rasters essentially modifies the GIS resource (a mosaic dataset), and restarting or overwriting the service is necessary after updating settings in the underlying GIS resource.
Solution or Workaround
Restart the image service after adding or deleting rasters in the referenced mosaic dataset.
Article ID:000013829
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
