PROBLEM
Unable to add a field in the attribute table of a feature collection
Users are unable to add a new field to the attribute table of a feature collection in ArcGIS Online.
Cause
This is by design. New fields cannot be added to a feature collection because the changes done to the feature collection are only temporarily reflected in the web map, and not applied to the original data.
Solution or Workaround
As a workaround, follow the instructions provided below to publish the feature collection layer as a hosted feature service, before adding a new field to the service.
  1. Log in to ArcGIS Online, and open the My Content page.
  2. Click the drop-down arrow next to the feature collection layer (listed as Feature Layer under the Type section), and click View item details.
  3. Publish the layer. A hosted feature service is now created. For more information, refer to ArcGIS Online Help: Publish a feature collection.
  4. Open the hosted feature service in the map viewer.
  5. Open the attribute table by clicking the Show Table button from the Contents window.
  6. Click Table Options > Add Field. For more information on adding a field to a feature service, refer to ArcGIS Online Help: Add a field.
Only the owner of a hosted feature layer or an administrator of the organization is able to make changes to the attribute schema.
Article ID:000013367
Software:
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
