English
Bug: Scene services fail to render after upgrading ArcGIS Data Store from 10.3.1 to version 10.4 or 10.4.1.
After upgrading the ArcGIS Data Store from 10.3.1 to 10.4 or 10.4.1, scene services fail to render from the Web Scene Viewer in the Portal for ArcGIS website.
Workaround
Unregister and re-register the data store.
  1. Open a command prompt as an administrator, and change directories to the ArcGIS Data Store tools directory.
The default location on Windows is:  C:\program files\arcgis\datastore\tools.
On Linux, it is:   /home/installeduser/arcgis/datastore/tools.
  1. Run the unregisterdatastore command.
For example:
Windows: C:\Program Files\ArcGIS\DataStore\tools>unregisterdatastore.bat
Linux: $ ./unregisterdatastore.sh
  1. Run the registerdatastore command:
Usage: registerdatastore <serverURL> <serverAdmin> <serverAdminPassword>
For example:
Windows: C:\Program Files\ArcGIS\DataStore\tools>registerdatastore.bat https://gisserver.domain.com:6443 admin mIadminpw
Linux: ./registerdatastore.bat https://gisserver.domain.com:6443 admin mIadminpw
