BUG
The account used to run the Portal for ArcGIS and the ArcGIS Data Store services does not get set for non-English locales during installation
Last Published: January 27, 2023
When Portal for ArcGIS and ArcGIS Data Store are installed on non-English locales, the account running the services does not get set properly.  No error occurs during the installation; however, the Local System account is used for the service instead of the account specified during installation.  Furthermore, permissions are not properly set on the installed folders.
Additionally, running the configureserviceaccount.bat command-line utility to change the ArcGIS Data Store account or Portal for ArcGIS account generates the below error:
Error:
‘Error adding user to local group. RunAs configuration stopped due to an error’
Cause
This is due to the utility that sets the account for the Portal for ArcGIS and the ArcGIS Data Store requiring a group called ‘Users’, found in the Computer Management console.  This problem occurs on non-English operating systems that have the ‘Users’ group translated into the respective language.
Workaround
  1. Add a Windows group called ‘Users’ using the English alphabet to the Computer Management console after the installation completes.
  2. Open command prompt as an Administrator and run the ‘configureserviceaccount.bat’ utility to properly set the account and privileges.
    • For ArcGIS Data Store this is found in the <ArcGIS Data Store installation directory>\tools folder.
    • For Portal for ArcGIS this is found in the <Portal for ArcGIS installation directory>\tools\ConfigUtility folder.
Article ID:000013327
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
