English
Problem: Web AppBuilder for ArcGIS applications require login even when anonymous access is allowed
Accessing a Web AppBuilder for ArcGIS application, which has been configured for anonymous access, requires users to login.
Cause
This is a known issue related to the ArcGIS Online 3.6 update, which unchecks the 'Allow anonymous access to your organization' security settings in ArcGIS Online for Organizations.
Solution or Workaround
Enable the 'Allow anonymous access to your organization' security setting in ArcGIS Online for Organizations.
  1. Log in to the ArcGIS Online Organization as an administrator.
  2. Navigate to My Organization > Edit Settings > Security tab > Policies.
  3. Check the 'Allow anonymous access to your organization' check box.
    [O-Image]
  4. Save the settings.
Related Information
