Answer
On September 24, 2014 a security vulnerability was revealed affecting the standard bash login shell which is broadly deployed on Linux server hosts. This vulnerability does not impact ArcGIS Online, ArcGIS for Server, or Portal for ArcGIS.
However, if you have deployed Esri products on Linux, we highly recommend applying your Linux vendor's security patches immediately. This also applies if you are utilizing one of our ArcGIS Server Ubuntu Amazon Machine Images (AMI).
Article ID:000013280
Software:
- ArcGIS Server
- Portal for ArcGIS
