English
How To: Set a map document's properties using ArcObjects
Summary
In ArcMap, there is a Map Document Properties dialog that shows the following information fields about the .mxd file: Title, Summary, Description, Author, Credits, Tags and Hyperlink base.
The Map Document Properties dialog box
[O-Image]
Instructions provided describe how to access and changes these properties via the IDocumentInfo2 interface.
Procedure
The samples below show how to change the author, title, and description of the document.
  • VB.NET Sample
    Code:
    Dim pMapDoc As IMapDocument = New MapDocument()
    pMapDoc.Open("C:\\Untitled.mxd")
    Dim pDocInfo As IDocumentInfo2 = pMapDoc
    'Change the author of the document
    pDocInfo.Author = "Esri"
    'Change the title of the document.
    pDocInfo.DocumentTitle = "My Map Document"
    'Change the description of the document
    pDocInfo.Comments = "This is a demo."
    'Save the change
    pMapDoc.Save()
  • C# Sample
    Code:
    IMapDocument pMapDoc = new MapDocument();
    pMapDoc.Open("C:\\Untitled.mxd");
    IDocumentInfo2 pDocInfo = (IDocumentInfo2) pMapDoc;
    //Change the author of the document
    pDocInfo.Author = "Esri";
    //Change the title of the document.
    pDocInfo.DocumentTitle = "My Map Document";
    //Change the description of the document
    pDocInfo.Comments = "This is a demo.";
    //Save the change
    pMapDoc.Save();
  • JAVA Sample
    Code:
    pMapDoc.open("C:\\Untitled.mxd", "");
    IDocumentInfo2 pDocInfo = (IDocumentInfo2) pMapDoc ;
    pDocInfo.setAuthor("Esri");
    pDocInfo.setDocumentTitle ("My Map Document");
    //Change the description of the documentpDocInfo.setComments ("This is a demo.");
    //Save the change
    pMapDoc.save(false, false);
Related Information
