HOW TO
Set up web security using Windows Authentication with IIS for Workflow Manager Flex viewer
Last Published: April 26, 2020
Summary
Web security can be set up in Workflow Manager viewers using Windows Authentication with IIS.
Instructions provided explain how to set up web security for the Flex viewer.
Procedure
  1. Enable Windows Authentication in IIS.
  2. In the Flex viewer folder, rename the file 'default.windows_auth.aspx' to 'default.aspx'.
  3. Rename index.html, so that it is not used.
  4. Open the Flex viewer using the url -
    'http://your-server-name/website-name/'. Some web browsers automatically log users in. If not, enter the user login information and click OK.
Article ID:000013267
Software:
  • ArcGIS Workflow Manager for Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
