ERROR
Client software failed to load. Be sure the database client software is installed and configured correctly
Last Published: April 26, 2020
Error Message
When attempting to connect to an Oracle database from an ArcGIS application, the following error occurs:
"Client software failed to load. Be sure the database client software is installed and configured correctly."
Cause
This error may occur for the following reasons:
A. No client is installed on the ArcGIS for Desktop machine.
B. Only the 64-bit client is installed when attempting to connect to Oracle from ArcMap or ArcCatalog, which are 32-bit applications.
C. Only the 32-bit client is installed when attempting to connect to Oracle from ArcGIS for Server or ArcGIS Pro, which are 64-bit applications.
Solution or Workaround
To solve the issue, ensure that the client is installed and that the bit-level of the client matches the bit-level of the connecting application.
If both the 32-bit client and the 64-bit clients are installed on the same machine, the 64-bit client must be listed first in the PATH environmental variable for a Windows operating system.
Article ID:000013262
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
