English
Problem: The required library, libexpat.so.0, is no longer available on SUSE Linux 11 SP2, SP3 and SP4
When running the ArcObjects SDK for Cross Platform C++ on SUSE Linux Enterprise 11, the required library, 'libexpat.so.0', no longer ships with SUSE Linux Enterprise 11 SP2, SP3 or SP4.
Cause
The libexpat.so.0 library has been replaced with libexpat.so.1 on SUSE Linux Enterprise 11 service packs after SP1.
Solution or Workaround
Create a symbolic link:
Code:
ln -s /lib/libexpat.so.1 $ARCENGINEHOME/bin/libexpat.so.0
