Frequently asked question
What are the build numbers for releases of the Esri Aeronautical Solution?
Last Published: June 28, 2021
Answer
The Esri Aeronautical Solution is now known as ArcGIS Aviation Charting, an extension of ArcMap, and part of the ArcGIS Mapping and Charting Solutions.
Esri Aeronautical Solution 10.1
Esri Aeronautical Solution 10.1 = 1074
Esri Aeronautical Solution 10.1 Patch 1 = 1246
Esri Aeronautical Solution 10.1 Patch 2 = 1327
Esri Aeronautical Solution 10.1 Service Pack 1 = 1396
Esri Aeronautical Solution 10.1 Service Pack 1, Patch 1 = 1488
Esri Aeronautical Solution 10 = 406
Esri Aeronautical Solution 10 Service Pack 1 = 649
Esri Aeronautical Solution 10 Service Pack 2 = 904
Esri Aeronautical Solution 10 Service Pack 3 = 1026
Esri Aeronautical Solution 10 Service Pack 4 = 1158
Article ID:000013217
Software:
  • ArcGIS Aviation Charting
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
