PROBLEM
The Sign In and ArcGIS Online options are inactive on the File menu
Last Published: September 20, 2021
Hosted feature services cannot be published from ArcMap because the Sign In and ArcGIS Online options when clicking on the File menu are inactive. The Sign In option allows users to log in to ArcGIS Online from ArcMap, and the ArcGIS Online option allows users to access data and maps uploaded to ArcGIS Online.
The Sign In and ArcGIS Online options inactive in ArcMap
Cause
  • The ArcGIS Connection Utility is disconnected because the ArcGIS Connection Properties is set to 'Never check'. This setting allows ArcGIS Desktop to check for ArcGIS Online's availability. A globe icon symbolizes a good connection; a globe icon with a red 'X' symbolizes a bad connection.
The disconnected ArcGIS Connection icon
  • ArcMap is referencing an incorrect ArcGIS Online connection. In ArcGIS Administrator, the default ArcGIS Online connection (www.arcgis.com) is referenced instead of the organizational domain.
  • TLS 1.2 is not enabled in the machine.
  • The domains are blocked.
Solution or Workaround
Use one of the workarounds listed below to solve the issue.
Re-establish the ArcGIS Connection Utility
  1. Open ArcMap. Click the Show hidden icons button on the Windows taskbar
  2. Locate the disconnected ArcGIS Connection globe icon on the taskbar.
The Show hidden icons and the disconnected ArcGIS Connection icon
  1. Right-click the ArcGIS Connection icon and click ‘Properties…’.
The ArcGIS Connection icon only displays after launching ArcMap.
  1. In the ArcGIS Connection Properties dialog box, under Connection Test Frequency, select the Always check at the start of a session option, and click OK.
The ArcGIS Connection Properties dialog box with the Always check at the start of a session option checked.
  1. The ArcGIS Connection Utility is now connected. Hover the cursor over the ArcGIS Connection icon to check the status.
The ArcGIS Connection icon showing it is connected
Add the ArcGIS Online organizational domain in ArcGIS Administrator
Refer to ArcMap: Manage ArcMap portal connections for steps to add the organizational domain in ArcGIS Administrator.
Additionally, add https://www.arcgis.com to the portal connection.
Warning:
Esri cannot guarantee results from incorrect modifications while following these instructions. Exercise caution. Consult a qualified computer systems professional if necessary.
Enable the TLS 1.2 option in the machine
  1. On the Windows taskbar, click Start.
  2. Search for and select Control Panel.
  3. In the Control Panel window, click Network and Internet > Internet Options.
  4. In the Internet Properties window, click the Advanced tab.
  5. Under Settings, check the Use TLS 1.2 check box.
  6. Click Apply > OK.
Enable the Use TLS 1.2 option to allow ArcGIS Online connection.
Reset the Internet Explorer settings
  5. Under Reset Internet Explorer settings, click the Reset... button.
Add the required domains to the exceptions of the firewall
Add the domains to the allow list to enable the connection to ArcGIS Online. Refer to Esri Blog: Troubleshooting issues adding ArcGIS Online basemaps to ArcMap for more information.
Article ID:000013176
Software:
  • ArcMap
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
