BUG
Web Map services on Linux crash when performing a GetCapabilities request
If the web map service (WMS) capability is enabled on Sample World Cities, clicking the WMS link from the REST endpoint for the service returns an HTTP 400 error.
"The request sent by the client was syntactically incorrect."
[O-Image] The request sent by the client was syntactically incorrect
Viewing the server logs reveals the Sample World Cities service crash. The following severe error is logged with ArcGIS Server and an error report is generated.
"Error handling request to service '.MapServer'. java.io.IOException: Server object extension 'wmsserver' not found."
Connection from ArcMap also fails.
[O-Image] An event was unable to invoke any of the subscribers
Cause
This is a known issue.
Workaround
  1. Download the ArcGIS 10.3.1 for Server (Linux) WMS GetCapabilities Patch, available from the Esri Support website.
  2. Follow the directions provided on the page in the above link.
    Article ID:000012809
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
