PROBLEM
When accessing ArcGIS Server resources through a web adaptor that has been set up on an Oracle WebLogic web server, requests take 20 seconds or longer, and sometimes do not complete.
An issue within the WebLogic web server causes cached requests to stop responding.
Oracle's suggested fix for this problem is to change the SSL implementation used internally within WebLogic. In most cases this will fix the issue regardless of whether the requests are being made via HTTPS.
Warning: The following steps are not fully supported by Esri, as technically the change is being made to the Oracle WebLogic server.
Code: -DUseSunHttpHandler=true
Get help from ArcGIS experts
Download the Esri Support App
