English
How To: Prepare data for use with the Network Analyst extension
Summary
Instructions provide a tutorial (data provided) with the steps for cleaning up data and adding new fields used by Network Analyst.
This article is intended for ArcGIS Desktop 10.1 and later, and this solution does not work with earlier versions.
Procedure
Download and unzip the data, NA_Data_Prep_Tutorial.zip, from the Related Information section below. After the download is complete, follow the instructions located in ArcGIS Network Analyst data prep tutorial.docx.
    Related Information
