English
FAQ: Is it possible to export a geodatabase schema to a UML object model?
Question
Answer
No; a geodatabase schema can be created from a UML object model using the schema wizard in ArcCatalog. It is not possible, however, to reverse-engineer a UML object model from a geodatabase schema.
