Frequently asked question
What is the proper SQL syntax for date field queries in ArcGIS?
Last Published: April 26, 2020
Answer
The SQL syntax for querying date fields varies according to DBMS. Unfortunately it can vary widely, even though SQL is the standard and most popular DBMSs use for queries. The following examples should be helpful:
Personal Geodatabases:
[DATE_FIELD] = #1970/8/17#
[DATE_FIELD] = DateSerial(1970,8,17)
Coverages, shapefiles and SDE geodatabases comply with SQL standards:
"DATE_FIELD" = date '1970/8/17'
Data formats and SQL syntax for some DBMSs or versions of DBMSs may be different than what is shown above. For more information, check the Select by Attributes dialog box by clicking either Help or the SQL Info button.
Article ID:000012736
Software:
  • Legacy Products
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
