ERROR
An expected Field was not found or could not be retrieved properly
Last Published: April 26, 2020
Error Message
When using the Query Builder in the Make Query Table tool to build an SQL query with two or more tables or feature classes (or both) as the input data, the tool fails to execute and returns the generic error 999999, with the following explanation:
Error:
"ERROR 999999: Error executing function
An expected Field was not found or could not be retrieved properly."
[O-Image]
This issue occurs in ArcGIS for Desktop 10.2.1, 10.2.2, 10.3, and 10.3.1. The bug ID logged for this issue is NIM-102585.
Cause
The error occurs because double quotes are added automatically to the SQL query expression in the Query Builder of the Make Query Table tool when there are two or more input data tables. String values with double quotes are considered invalid syntax in SQL query expressions.
[O-Image]
Solution or Workaround
Manually remove the double quotes from the SQL query expression for the tool to execute successfully.
    Article ID:000012711
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
