HOW TO
Use many-to-many joins via a query layer
Last Published: April 26, 2020
Summary
Many-to-many joins are difficult to handle with ArcGIS. The table grid in ArcMap requires a unique identifier for each row in a table and this condition is violated by joins of this type. Currently the table grid displays one of the matching rows. The matching row selected for display is effectively random.
Through the use of a query layer, many-to-many joins can be more effectively handled. The table grid behaves similarly to the RDBMS and queries against the data are more consistent with the expected behavior.
Procedure
Any variation of the Add Query Layer tool can be used to create the layer.
• File > Add Data > Add Query Layer
• Make Query Layer in the Data Management > Layers and Table Views toolbox
The results are the same whatever tool is used.
  1. In ArcMap bring up the New Query Layer tool: File > Add Data > Add Query Layer.
  2. Under Connections, connect to the data source.
  3. Enter a query establishing a left outer join between the tables. Do not use asterisks (*) in the SELECT list.
    Provide a qualified list of all of the fields to be returned. Field names cannot be duplicates and must be aliased.
    Table1: streets
    Table2: busroutes
    Join Field: street_id
    SELECT streets.objectid, busroutes.objectid as busoid, streets.street_id,
    busroutes.route_id, busroutes.route_name, streets.street_name, streets.street_block_length
    FROM streets LEFT OUTER JOIN busroutes ON streets.street_id = busroutes.street_id;
    A WHERE clause can be used if needed. For example, it may be desirable to return only the rows for a particular bus route, (WHERE busroutes.route_id = 12).
  4. Use the ObjectID from each table as unique identifier fields.
  5. Click Finish.
    The query layer is added to the Table of Contents. All matching rows display in the table grid. Duplicate geometries display when there are multiple matches.
    This works for ArcMap and ArcGIS Pro. It is persisted by saving the map document or project. If published to a map service, the query layer can be queried and displayed.
Article ID:000012705
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
