PROBLEM
When changing field names in ArcGIS Pro, the changes are not saved if capitalization is the only change made.
EXAMPLE:
Initial field name: fieldone
Desired field name: FieldOne
A geodatabase does not recognize the difference between case type. Although there is a difference between 'FeatureLayer' and 'FEATURELAYER', it is read the same way in the table.
Get help from ArcGIS experts
Download the Esri Support App
