ERROR
Invalid folder location. Unable to access this location
Last Published: May 5, 2022
Error Message
When attempting to register a folder in ArcGIS for Desktop or ArcGIS Server Manager, the operation fails and returns the following error:
"Invalid folder location. Unable to access this location."
[O-Image]
Cause
There are several possible reasons for this issue:
  • The ArcGIS Server account is unable to access the location specified.
  • When an absolute path is used instead of a UNC path to register a folder present on one of the ArcGIS Server machines in a multi-machine site. For more information about paths, refer to the following web help document, ArcGIS Help: Paths explained: Absolute, relative, UNC, and URL.
  • The desired folder for registration and ArcGIS for Server are on different machines.
  • The desired folder for registration is on a domain controller for Active Directory. Local accounts cannot be created on a machine with an Active Directory domain controller, so explicit permissions cannot be granted to the local ArcGIS account, preventing the registration process. For more information about domain controllers, refer to the following web help document, ArcGIS Help: Configuring the domain controller used by ArcGIS Server.
Solution or Workaround
Use one of the following options to solve this issue:
Article ID:000012653
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
