PROBLEM
When exporting a feature class to a new feature class, the original ObjectIDs are not maintained in the new feature class. Occasionally, the original ObjectIDs must be maintained because they are used in existing workflows or functions.
When features are deleted or edited, the ObjectID range can vary and the order can change. For example, the values may start from a number other than 1, or there are large sections of numbers missing, such as 1- 10, 25 – 50, and so on. This is because when features or records are deleted or edited, ObjectIDs continually build in sequential order and do not replace values which were deleted.
For more information, refer to the following article, FAQ: Are ObjectID values repeated for features in a feature class or for records in a table?
The regeneration of ObjectIDs after exporting or creating a new output feature class is by design; ArcGIS assigns a new set of ObjectIDs to a feature class when it is exported. The ObjectIDs are unique IDs to identify rows in tables in a geodatabase and start from 1 and end at a particular number. ArcGIS automatically assigns and manages ObjectIDs to tables or feature classes when both elements are created via ArcGIS, or were created outside ArcGIS and registered with the geodatabase.
To maintain the original ObjectIDs in the exported feature class, create a new field (for example, OriginalOIDs) in the original feature class before exporting, and populate the values using the Field Calculator.
Get help from ArcGIS experts
Download the Esri Support App
