English
Error: ImportError: No module named arcpy
Error Message
When attempting to import arcpy using 64-bit Python that comes with an ArcGIS Server installation, the following error message appears:
"ImportError: No module named arcpy"
Cause
The arcpy module's location probably isn't specified correctly within the Server10.x.pth file. This file is in the following location:
 <install-drive>\python27\Lib\site-packages
Solution or Workaround
1. Ensure that the following locations are specified in the Server10.3.pth file (the version of ArcGIS Server determines the name of the .pth file):
C:\Program Files\ArcGIS\Server\arcpy
C:\Program Files\ArcGIS\Server\bin
C:\Program Files\ArcGIS\Server\ArcToolbox\Scripts
The ArcGIS Server Installer also utilizes the sys.path functions and adds the following location to the system path:
C:\Program Files\ArcGIS\Server10.3\arcpy
2. From the main toolbar in ArcMap, open the Python window and run the following commands:
>>> import sys
>>> print sys.path
3. Verify that arcpy is in the system path.
['', u'c:\\program files\\arcgis\\server\\arcpy', 'C:\\windows\\system32', 'C:\\Python27\\ArcGISx6410.3\\Lib\\idlelib',
'C:\\windows\\system32\\python27.zip', 'C:\\Python27\\ArcGISx6410.3\\DLLs', 'C:\\Python27\\ArcGISx6410.3\\lib',
'C:\\Python27\\ArcGISx6410.3\\lib\\plat-win', 'C:\\Python27\\ArcGISx6410.3\\lib\\lib-tk', 'C:\\Python27\\ArcGISx6410.3',
'C:\\Python27\\ArcGISx6410.3\\lib\\site-packages', 'C:\\Program Files\\ArcGIS\\Server\\bin',
'C:\\Program Files\\ArcGIS\\Server\\ArcPy', 'C:\\Program Files\\ArcGIS\\Server\\ArcToolBox\\Scripts']
Python checks both 'sys.path' and the 'Server10.3.pth' file for a module named 'arcpy' when importing arcpy. As long as the location of arcpy is specified, importing arcpy will be successful:
>>> import arcpy
