HOW TO
Copy a search service configuration to other machines in the organization
Last Published: April 26, 2020
Summary
After configuring an ArcGIS Server search service for use in ArcMap, it is important to ensure the entire organization has the same enterprise search configured on each machine. To avoid having to reconfigure each machine manually, there is a .cfg file that can be copied to these machines.
This can be useful when a Citrix-based access point for Desktop users is implemented and users need the same enterprise search configured.
Procedure
  1. Configure a search service for use in ArcMap. See ArcGIS Web Help: Search services for more information.
  2. Navigate to the folder path below.
    C:\Users\<user>\AppData\Local\ESRI\Desktop10.3\ArcCatalog\SearchIndex\Configs\
  3. After establishing a search service on the local machine, copy the 'SearchOptions.cfg' file from the folder location above, and copy this file to the desired target machines. Delete the older file.
Article ID:000012623
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
