Frequently asked question
Is it possible to turn off the grey globe with 3D view in ArcGIS Pro?
Last Published: April 26, 2020
Answer
No, it is not possible to turn off the grey globe with 3D view in ArcGIS Pro because the grey globe is considered as the reference layer; removing the grey globe leaves the project without a reference layer.
[O-Image]
In a case where feature classes with negative elevations are present, and the feature is invisible, follow the procedure in the following article, Problem: The elevation surface in a 3D scene blocks some features
Article ID:000012586
Software:
  • ArcGIS Pro 1 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
