English
Problem: Editing vertices of a polygon rotates the entire feature
When moving vertices for a polygon feature in ArcMap during an edit session, the feature rotates and changes size.
[O-Image]
Cause
This issue occurs because the Stretch Proportionately option is enabled. This option gets automatically enabled when any spatial adjustments are performed on the data.
[O-Image]
Solution or Workaround
There are two possible solutions to this issue:
Solution 1
Disable the Stretch Proportionately option by clicking the button to deselect the option via the Edit Vertices toolbar.
Solution 2
Disable the option from the Editor Toolbar using the following steps:
1. In the Editor toolbar, click the Editor menu, and click Options. This opens the Editing Options window.
2. Select the General tab and uncheck the 'Stretch geometry proportionately when moving a vertex' check box.
[O-Image]
3. Click OK. The Stretch Proportionately option is disabled.
Related Information
