Frequently asked question
Is it possible to create hyperlinks for data stored in a local drive in an ArcGIS Online web map?
Last Published: April 26, 2020
No, it is not possible to create hyperlinks for data stored in a local drive in an ArcGIS Online web map. This known limitation in ArcGIS Online is designed to prevent any compromises in privacy and security.
A workaround for this limitation is to upload the desired data to a file-hosting website or a local server, and hyperlink the data via a URL to the uploaded data in the targeted ArcGIS Online web map. Since there is no direct functionality that creates hyperlinks, pop-ups are used to display the URLs instead.
The instructions provided describe how to create a pop-up that displays the URL of the uploaded data. The data in this example is an image. The URL configured in a pop-up serves as a 'hyperlink' in an ArcGIS Online web map.
  1. Upload the desired data to a hosting website or a local server and save the URL of the data.
  2. In the ArcGIS Online web map, click the Configure Pop-up option for the selected feature layer.
[O-Image]
  1. In the Pop-up Media section of the Configure Pop-up dialog, click the Add drop-down menu and select Image. Click SAVE POP-UP. This opens the Configure Image dialog box.
[O-Image]
  1. In the Configure Image dialog box, copy the image URL and paste it into the URL field of the dialog box. Click OK.
[O-Image]
  1. Save the pop-up, and save the layer.
Article ID: 000012569
Software:
  • ArcGIS Online
Download the Esri Support App
Get help from ArcGIS experts
Contact technical support
Go to download options
Esri Support AI Chatbot
