Frequently asked question
Is it possible to run a workflow on a subset or a filter of an object in Esri Maps for Salesforce?
Last Published: April 26, 2020
Answer
No, as of Esri Maps for Salesforce 1.1, it is not possible to run a workflow on a subset or filter of an object as an alternative to running the workflow on the entire object.
However, a view or filter can be created when adding data from Salesforce or ArcGIS Online. This allows only the desired data to be recorded as a new layer.
Filtering objects when creating a layer allows for better control of the number of records added, hence increasing the performance when running a workflow.
For more information on setting filter criteria when adding data, refer to the following documentation, Esri Maps for Salesforce: Add data from Salesforce and Esri Maps for Salesforce: Add data from ArcGIS.
Article ID:000012568
Software:
  • ArcGIS Maps for Salesforce 1 0
  • ArcGIS Maps for Salesforce 1 1
  • ArcGIS Maps for Salesforce 1 2
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
