ERROR
000483: Address standardization failed
Last Published: February 9, 2021
Error Message
In ArcMap, when attempting to standardize addresses in a table using the Standardize Addresses geoprocessing tool, the following error is returned.
Error:
Error: 000483: Address standardization failed.
Image of the error.
Cause
This error occurs when conditions for the Output Address Data parameter are not met. The tool's Output Address Data Parameter requires saving the output table in a file geodatabase or adding a table extension if the table is saved to a folder.
Solution or Workaround
Save the output table in a file geodatabase, or manually add the dBASE (.dbf) file extension when saving the output table in a folder.
Article ID:000012559
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
