HOW TO
Create TIN triangles from contour lines
Last Published: April 26, 2020
Summary
Triangulated irregular networks (TIN) are a form of vector-based digital geographic data constructed by triangulating a set of vertices. The connection of the vertices with a series of edges forms a network of triangles. TIN surfaces can be created from vector data, raster data, and terrain datasets.
The instructions provided describe how to create TIN triangles from contour lines.
Procedure
A 3D Analyst license is required to use the tools mentioned in the instructions below.
  1. In the Catalog window, open the Create TIN tool by navigating to Toolboxes > System Toolboxes > 3D Analyst toolbox > Data Management > TIN > Create TIN.
    [O-Image]
  2. Ensure the data being created are aligned. Select the appropriate coordinate system by clicking the button next to the Coordinate System text box.
    [O-Image]
  3. Select the contour layer as the Input Feature Class.
  4. Select the field containing the elevation values for the Height Field.
    [O-Image]
  5. Select Mass_Points for the SF Type.
  6. Check the Constrained Delauney check box, and click OK.
    [O-Image]
    The TIN data is displayed in the map.
    By using the constrained Delauney triangulation, the breaklines are not densified, and each breakline segment is added as a single edge.
  7. In the Catalog window, open the TIN Triangle tool by navigating to Toolboxes > System Toolboxes > 3D Analyst Tools > Conversion > From TIN > TIN Triangle.
    [O-Image]
  8. Click the Input TIN drop-down arrow, and select a TIN layer as the input. Click OK. The TIN triangles are displayed in the map.
    [O-Image]
Article ID:000012532
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
