PROBLEM
Unable to run backup.py or restore.py in ArcGIS for Server after applying the January 2015 security patch
Last Published: April 26, 2020
After applying the ArcGIS for Server Security Patch (January 2015), running the Python scripts backup.py or restore.py, included in the ArcGIS\Server\tools\admin folder, both fail when attempting to access ArcGIS for Server over port 6443.
Cause
One of the changes included in the January 2015 ArcGIS for Server security patch was to disable the SSLv3 cryptographic protocol due to a security vulnerability. This protocol was commonly used to provide secure communication over HTTPS. Python 2.7.5, which is installed with ArcGIS for Server 10.2.1 and 10.2.2, uses SSLv3 by default when communicating over HTTPS and does not attempt a different protocol if it fails. Hence the backup.py and restore.py scripts are unable to communicate with ArcGIS for Server using port 6443 after applying the security patch.
Solution or Workaround
There are two options to work around this issue:
Option A
Upgrade to ArcGIS for Server 10.3. Python 2.7.8 is included with this version and does not rely on SSLv3 to communicate over HTTPS.
Option B
Manually upgrade the 64-bit version of Python used by ArcGIS for Server v 10.2. As indicated previously, Python 2.7.5 (64-bit) is distributed with ArcGIS for Server 10.2.1 and 10.2.2. Python 2.7.8 can be downloaded directly from python.org and installed to overwrite the existing version of Python. When installing a newer version of Python, make sure to install it in the same folder as the existing version:
C:\Python27\ArcGISx6410.2
Warning:
Overwriting the existing version of Python must be done with a 64-bit version and must remain in the 2.7 series. Upgrading to Python 3 or higher causes other failures.
If ArcGIS Engine 10.2.1 or 10.2.2 is installed on the same machine after manually upgrading Python, Python is downgraded back to 2.7.5 and the newer version must be reinstalled.
Article ID:000012525
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
